Katherine91
20 points
Posted on - 07/22/2011
Hello masters
I am interested in learning about virtual hosting anyone know any shared hosting services that allow existing facilities DSN wildcard..?
My plan will create a virtual web of existing facilities webs .com rich sub domain but would first try to use, a shared hosting without having to use private hosting.
jonno
Shared hosting can use for virtual sub domains?
no
share hosting is not abail to use in virtual sub domain
if you want to host your sub domain than you need to use windose server for this
but this is not usable to worldwide
it can use only use for lan connection. and after configure a lan internet then you can upload your domain on your Windows Server pc. remember that it will be apachi server will be needed to host your site. otherwise it will not be work.
if all is on then you put your web file on htdocs folder at apachi server software. now you can use you sub domain as your local internet web site.
if you need more help to configure this than you can contact with me by write a comment in here
thanking you,
jonnno
nice great to hear if it is can use for lan connection. I need to learn fist before upload to hosting.. Thanks Jonno
