Sharepoint 2010 law office template for Mac
I made some SharePoint 2010 files in last computer. Now I purchase Mac Mini. I want to use these files in Mac. How can I open SharePoint 2010 office templates in Mac Mini?
There should be no problem opening the files or templates on the Mac computer if you install the Mac version of Microsoft SharePoint 2010 on your computer. There would be no problem opening the files even if they are created under Windows operating system. The only thing you should do now is to find a Mac version of the software then install it on your machine.
You should check if there is a Macintosh version of Microsoft SharePoint 2010 to enable you to open the files or templates on your Mac. I’ve checked it already and there is a Mac version of the software. The only thing you should do now is to check with Microsoft to know the latest version of the program that works on Mac.
