I am making my own web site. I want to use a rotator on my site as like in share point 2010 text and image rotator. Different images should change dynamically during different page loads, but I have no idea how can I use it. Please help me and give me an idea . How I can use this rotator in my web site?.
Sharepoint 2010 text and image rotator
Hi Harford,
There are two ways on how to use text and image rotator.
First, go to this page:Â http://www.amrein.com/apps/page.asp?Q=5780
By adding a script to a Content Editor Web part the rotator works which randomly displays pictures from a SharePoint picture library. Another option is using JavaScript set interval function.
Hope it will help you.
I think I found a good solution for this. I recently came across this program which has great flexibility and multiple features. It works as simple image and text rotator and also can perform some advanced slideshows.Â
If you have it, you don’t need any scripting or any other program. The basic requirement is just having a Flask Player of version 10 or later. There are almost 500 options and more than 20 stellar transitions for professional presentation. It is XML driven and so easy for any web developer.
I would say it is even better than the Share point image and a text editor
Hope it will solve your query nicely.Â
