SharePoint 2013 Server Store Error
I am facing problem in SharePoint Store and getting ERROR.
configuring SharePoint 2013 on a new SharePoint Server's environment
I am configuring SharePoint 2013 on a new SharePoint Server's environment and it was working well, I was able to download and install some Applications and thought I would do it a next day and I had accomplished something.
The next day I start to complete, I tried to Add an App and received this error.
Sorry, we can't seem to connect to the SharePoint Store.
Try again in a bit.
Best Answer by Shifflett Laurel
Answered By 0 points N/A #169457
Hello shfmtl,
I have confirmed about the matter. I am saying confidently that there is an App management shared service that you need to add to the Farm. You will probably need to configure the Subscriptions setting service also.
Moreover you have to know all about Localization an app for SharePoint by using resource files, JavaScript "resource" files, and other techniques.
This has some significant point:
  • Prerequisites for localizing an app for SharePoint.
  • Localizing the app web components.
  • Localizing the host web components.
  • Including localized apps for Office in the app for SharePoint.
  • Localizing remote components in an auto hosted app for SharePoint.
  • Localizing remote components into a provider-hosted app for SharePoint.
  • Additional resources.
  • Change history.
For further details go to https://docs.microsoft.com/en-us/sharepoint/dev/sp-add-ins/localize-sharepoint-add-ins
Thanking you.
Shifflett Laurel
Answered By 0 points N/A #169458
I believe that the following method can help you resolve the problem you are facing.
1. Go to Central Admin and then to ‘Manage Web Application’.
2. Select the application and go to ‘Manage features, and activate internet access to the store.
3. Ensure that the following are taken care.
Apps that require accessible internet facing endpoints
Allow users to acquire apps that require internet facing endpoints from the SharePoint Store.
4. Reset and everything might work fine.
