SharePoint Avery address labels prints on edge of paper
Hi fellow Techyv members.  I'm having a hard time printing Avery address labels using SharePoint on my HP k510a PhotoSmart all in one printer.  It keeps on printing on the edge of the paper disregarding the margin space on top.  Anyone having the same SharePoint Avery address labels problem?
Answered By 0 points N/A #198439
Hi Elyssaguadalupe,
I think that you have to adjust your ruler tickers on the upper and on the left side of your screen. If you haven't seen them before. Go to views and go to tick the ruler checkbox, at the time that you have ticked them, the ruler will pop out. Select the ticker, the one that has small triangle shape on the ruler and drag it inward of the screen. That should do it.
