SharePoint that can display Lotus Notes as XML data
Please help me locate a software or any resources that can help to make SharePoint connect and display Lotus Notes as XML data? Is such an application available?
Some important point to note is that XML will provide a cross-platform data format which will be very useful when you have to integrate SharePoint Server and Notes or Domino. What happens is that the data from SharePoint Server will be listed and the lotus Notes databases can both be provided as XML documents. After that has been done, the data will be in the XML format, and that way you will able to easily repurpose that data for integration between the platforms that you using. And therefore if is pretty clear from the observation that I have just mentioned that you can be able to display lotus notes as xml data.
-Thompson Locker
