I am using Sharepoint on my system, but while running it gives the following error and doesn’t perform any functionality. Can someone help me to resolve this issue?
Message from webpage
The list cannot be displayed in datasheet view for one or more of following reasons:
A datasheet component compatible with Windows Sharepoint services is not installed. Your web browser does not support ActiveX controls. Support for ActiveX controls is disabled.
Sharepoint error while running it
If you have installed the 64-bit version of Microsoft Office 2010, then you will not be able to view a list in Datasheet view on a SharePoint website. This is because of unavailability of a 64-bit of the Datasheet component of Office 2010.
The solution for this is to enable the Datasheet component by installing 2007 office system driver : Data connectivity components from Microsoft download center.
               OR
This error sometimes appears if ActiveX control settings are not set properly in Internet Explorer.
To verify it follow these steps:-
1. Open IE browser.
2. Go to Tools > Internet Options.
3. Click on Security tab and select Internet icon and click on Custom level.
4. Check the ActiveX controls and plug-ins.
5. Check the setting for "Download signed ActiveX controls", make sure Prompt radio button is selected.
6. Check the setting for "Run ActiveX controls and plug-ins", make sure Enable radio button is selected.
7. Check the setting for "Script ActiveX controls marked safe for scripting", make sure Enable radio button is selected.
Laz Zebbena
