I have recently downloaded Crossover 12.5 but with this new version, Sharescope is not working. What can the issue be here? Is there any kind of installation error or should I try out another version of Crossover?
Sharescope not working with CrossOver 12.5
I think you did the installation incorrectly that’s why you weren’t able to install ShareScope using CrossOver. ShareScope works and can be installed using CrossOver. CrossOver can install ShareScope Gold, ShareScope Plus, and ShareScope Pro. To make sure the installation runs correctly, download the latest version from CrossOver Mac 13.1.3. The one you have, CrossOver 12.5, is an outdated version.
Once downloaded, uninstall your existing application then install CrossOver Mac 13.1.3. For example, you want to install ShareScope Gold. To make this possible on your Mac OS X, download CrossTie. It is a component that instructs CrossOver how to install a Windows program. The CrossTie file includes the entire configuration settings required so that CrossOver will be able to create a new bottle or a virtual Windows environment and install the application to that bottle.
Once CrossTie is downloaded, open it in CrossOver and then CrossOver will automatically install ShareScope Gold.
