Sharewares from an Arcade deluxe vista
I am currently using an Acer Aspire laptop, what are things that can be downloaded from an arcade deluxe vista software? Are there shareware from that platform that is compatible with that of a vista operating system?
Best Answer by Huffman Serafin
Answered By 0 points N/A #198297
Hi Sheri Kay,
Acer Arcade Deluxe for Vista and for all Acer products is not available for download, the thing is, Acer has provided you the Disk upon purchase right? The Disk contains the Acer Arcade Deluxe that you are finding right now, if you want to install the Acer Arcade Deluxe, insert the Disk and perform a system restart, after it you can repair the whole windows operating system, in this case, the Acer Arcade Deluxe will be repaired and installed.
Answered By 0 points N/A #143374
Sheri,
All Acer computers come pre-installed with Acer Arcade Deluxe as a default program. This program has quite a wide range of functionality. It can be used to listen to music, check out photos, watch movies and use webcam to view YouTube and Flickr within a single program. The program is easy to use and can be used to download music.
