Can I share internet connectivity with my Samsung tablet 3 from HP laptop? Can I perform this task via laptop by serving as wifi hotspot instead of serving my smartphone? Are there any special requirements to perform this task? I would like to know different steps for this purpose; can anybody help me?
Sharing connectivity with Samsung tablet 3 from HP laptop
You can download and install ‘HP laptop to hotspot converter 7’ to connect internet from HP laptop to your Samsung galaxy tab 3.
HP Laptop to Hotspot Converter converts your HP laptop to a wireless hotspot. By this software, your HP laptop (Windows platform) is turned into a Wi-Fi hotspot so that you can share the Internet with your second laptop, friends or mobile devices. Of course you do not want to carry a wireless router while on the trip. But you have to find a Wi-Fi hotspot for your mobile. Laptop to Hotspot Converter Series software make your life easier. Now you can have your own hotspot anywhere.
You can follow the below steps to connect internet in laptop from Samsung phone.
Step 1: Go to ‘settings’ on your android phone.
Step 2: Select ‘Wireless and Network’.
Step 3: Go to ‘Access point settings’.
Step 4: Give a name to identify the access point inside the field named as ‘Router name (SSID)’.
Step 5: Choose security by scrolling to down and select option WPA2, to encrypt the exchange between the android device and access point.
Step 6: In the password field enter a password to use internet connection with security.
Step 7: Go back to ‘wireless and networks’.
Step 8: Check the box near to the ‘Portable Wi-Fi hotspot’. Now your Samsung galaxy tab will act as a gateway to the internet. You can connect it to the laptop as Wi-Fi.
Step 9: Open laptop and phone and search for available Wi-Fi connections.
Step 10: Select your access point.
