wylen
10 points
Posted on - 09/26/2011
I am working in Microsoft Word file. I want to share this file between two computers on the network because we want to work on this file simultaneously. Can anyone tell me how to share a Word document on network?
Sharing MS Word document between computers
Hello Weylen,
You don't have to worry it anymore this is very easy. There are alot of ways to do this. One way is you can make a folder where all your doc file will be save. Then make sure that Public Folder sharing is ON you can find it in the control panel then network and Internet then Network and Sharing Center then hit change advance sharing setting. (For Win 7 OS). After you turn it on you can now right click the folder and hit share with the option (read/write) so that the other user of the network can edit a certain share file document.
Hope it helps 🙂
