Sharing of Outlook Calendar b/w Computers
How can I share my outlook calendar between my computers so it will automatically update over my network?
To sync or share Outlook calendar between computers you must use an Exchange Server email account, and have the Navigation Pane turned on. Once you share your Outlook calendar, it means that the users you preferred sharing your calendar with will see and be able to access it. To share your Outlook calendar:
Sharing your calendar is possible between two or more computers. Microsoft provides this feature by publishing your calendar over Office.com and makes it easy for others to use them. But this feature will be ending in April, 2014. You simply login to your account Publish your calendar Invite others to view it. Google calendar also has this feature.
