Sharing pc screen on Samsung TV
Hi Experts,
I have a Samsung laptop with HDMI port and I buy a new Samsung TV with big display. I am trying to sharing pc screen on Samsung TV but it shows some kind of errors. Please suggest me, Is there any driver problem or any software need. Please help me for sharing pc screen on Samsung tv. Send me a complete solution. Thanks.
Laki Shafyfffe
Answered By 25 points N/A #171763
Hello! Good Day!
May I know what was the error all about?
Have you check whether you have enabled the HDMI port on your laptop? Check your laptop's video setting and make sure that HDMI is enabled.
Also, what is the model of your new Samsung laptop sir? Try to Google the model name/number and see if it has really a HDMI on board, because there are some laptops that "useless" ports. Like for example in HP Mini Series, it has a SIM Card slot but it has no use.
Hope this helps!
