Hi, there!
I’m using a Mobile Broadband Internet connection. I use Gmail for a daily basis. It was OK until today, but it stops sharing file with others. I can't send any file to others now. As a freelancer, it's so important to share a file.
I can't get what the problem is. Now, nobody can share a file with me and vice versa. I need an urgent solution. Please HELP!
Sharing Probs With GTalk (Chat Soft)
Hi!
Sharing files that suddenly does not work. The common problem is it could be the data itself is too big. G2G is a website that features easy transfer from gmail to gmail. Once your gmail is registered, then you can log-in to your gmail account and start sharing files.
This software allows you to do rapid share files with any recipients. If the file sharing won't work, check the data if it exceeded the maximum quota of 20MB.
This has to be checked for you to do the file sharing. If it exceeded, cut it into half and or decrease the data not more than 20MB.
