Hi guys,
SharpDevelop has encountered a problem while running on Microsoft's .NET 3.5 platforms.
It is showing the message as under. I cannot understand the message.
Please help.
SharpDevelop
Tortoise SVN needs to be installed to execute this action.
SharpDevelop has encountered a problem while running on Microsoft’s .NET 3.5 platforms
Hello Desirae,
It is more likely that you have installed the 64 bit version of Tortoise SVN. So you will need to either install the 32 bit version or you can go ahead and try adding the registry values that SharpDevelop looks for when it is attempting to locate Tortoise SVN.
It looks for the ProcPath registry value under one of the following keys.
HKCRSOFTWARETortoiseSVN
HKLMSOFTWARETortoiseSVN
Nicke
