Shellexecuteex Failed Error
When I’m installing any kind of software then my computer displays this messages, “A referral was returned to the server.” Can anybody tell me what happened and why is this error being showed? Can someone suggest a way to fix this?
Answered By 20 points N/A #319905
Technique 1:
Run this Microsoft fixit and check. Allude:
Fix issues that square projects from being introduced or evacuated.
If that doesn’t help, use technique 2.
Strategy 2:
Run framework document checker(SFC) and check whether it makes a difference.
Allude:
Utilize the System File Checker instrument to fix absent or debased framework documents.
Framework document checker is an utility in Windows that enables clients to examine for defilements in Windows framework records and reestablish undermined documents. Note: It might request Windows establishment DVD to fix and to empower SFC to make more than minor fixes. A few documents saved money on your PC may get erased when fixing adulterated records.
