I am getting the following error message using the Shockwave in Mac Operating System. It gives me the script error and if I click on ‘Yes’ the same error appears after a few seconds. Do you have any idea to fix this annoying error message? Any help would be appreciated so suggest me in a proper way. Thanks in advance.
Shockwave Error
Handler nog dettined
# findAnswer
Script Error. Continue?
Shockwave fails to run on Mac Operating System
Hello William,
Good day!
The problem that you are encounter is caused by an improper installation of Adobe Shockwave. To resolve this issue is you need to install Adobe Shockwave properly.
Follow this process:
· You need to navigate this link
· Kindly locate the Shockwave player section
· Just simply click the Shockwave Player uninstaller
· Please follow the on-screen instructions to uninstall the Shockwave completely
· Navigate this link to install the new version of Shockwave
· Kindly locate the Shockwave Player section
· Kindly click the Shockwave Player in the full installer section
· Reboot
Hope this may help you.
Quinn Poon
