Should I open acronis format file?
I found a file called acronis on my task manager. What is it? Should I open acronis format file or is it not safe? Is it a virus? What is this for?
Acronis is software, not a virus. It’s OK to open it. It makes backups for your computer, recovers hard drive software, does bare-metal restore and system deployment, and it's a storage manager for Windows and Linux systems.Â
Acronis has a number of products, like Acronis True Image, Acronis Rescue Media, and Acronis Secure Zone. You can check out its website:
Dear Conrad Nelson,
When you find a suspicious file on your computer and do not know where it comes from, you should scan it with antivirus software before opening it, or if you not antivirus software installed on your device you can scan it online with online scan software you can use avast online software scan on the following link.
After scanning it you are free to open it if the file was not infected.
