Should I upgrade Win 8 to Win 8 Pro now?
Hi guys,
I just got a gift from my friend which is the new Win 8 OS! The thing is, it is the normal Win 8 OS instead of the Win 8 Pro.
I know from my experience that Pro Edition is better in the case like Win XP Pro.
But since this Win 8 OS is a whole new thing, I wonder if it is necessary and worth it to upgrade to Win 8 Pro?
Best Answer by Floyd A Beverly
Answered By 240 points N/A #164462
Hi Dorothy,
I will try and help you as best as possible how I can, it is not very necessary but indeed it is worth it to upgrade because of the features that you get with the upgrade.
A Windows 8 upgrade is usually very good in that you don't have to choose which version of Windows 8 pro you download!
The Win 8 pro is a very ice option of windows in that it is really fast and easy to use.
Windows 8 Face
I hope this solves your query.
Thanks and regards.
Answered By 20 points N/A #164463
Hi Dorothy,
Have a nice day.
By reading your concern about Windows 8, I am suggesting you that let me know your system specification so that I can have a better idea of the problem. Pro windows 8 is better and Windows 8 is very reliable and easy to use. I also have experience of using Windows 8 pro edition, it is far better then XP pro.
But one thing should be kept in mind which is system specification. I will recommend you to install the Windows 8 but confirm the specification first.
