Should I use eusing register cleaner for my slow computer?
Hey guys,
All of a sudden my computer has slown down, my browser is slow and when I use programs I get a send error message. I think I need to defragment my disk. I've had my computer for a few years and it's never acted like this. I was told to you eusing register cleaner?
Answered By 5 points N/A #174570
Hello John
This problem means either your PC really needs a scan (viruses, spyware, malware) or a defragmentation.I guess that you have an anti-virus software installed. You should update it to its last version and run a full Scan to your computer.
Second thing to do, is to clear all the unused memory in your PC. For you, I suggest CCleaner. It is a very easy-to-use software, and guaranteed to do the job. You can Download it from this link., install it and run a full scan with it. After it finishes, you just reboot your computer and the problems should have gone away.
I hope you will find this information useful.
Randolph
Answered By 590495 points N/A #316366
If your computer suddenly became slow, first thing to do is check it for virus infection. Update your antivirus and perform a full system scan. You can also use a virus removal tool like Sophos Virus Removal Tool. Once installed, start Sophos then wait for the virus signature database to get updated. When updating is complete, click to start scanning your computer.
When a virus is found at the end of the scan, remove it then repeat the scan over and over until it no longer detects a virus. You don’t need to uninstall or disable your antivirus to use the tool. It works alongside any antivirus program you may have.
This tool is just a virus removal tool and cannot be used as a normal antivirus because it doesn’t have real-time protection. The program can be used for several months only. It will automatically stop working when it reaches the end of its usability period. If you want to use it again, you have to download a new copy.
