Show an error on QuickBooks Installer
While installing .Net 4.0. The QuickBooks 2012 installing process of the QuickBooks Installer shows the following error. Several more installs error will occur and then the install will then fail. Why has this happened?
.png)
Error:
The microsoft.Net Framework version v1.1 4322 or later must be installed before this package can be installed.
