Trevor Jhon
40 points
Posted on - 12/24/2012
How to show a file in vb open office hidden? I have two important software application in my computer desktop which is vb programming language and open office application. I saved all my database and Gui vb work in a specific folder together with open office files but when I opened the folders the data are not visible, how can I show those hidden files? I am using Windows 7 Os.
Waiting for your support.
Show Hidden VB Files in Windows 7 PC
It was hidden perhaps due to a virus. If that is the case, I suggest you scan your computer. Fortunately, you can still see them after they were made hidden. Follow the steps below:
1. Open my computer
2. Click tools
3. Click folder options
4. A window will appear. Click on the view tab
5. You will see the hidden files and folders. Check the show hidden files and folders.
6. Go to the folder of your file. You will see them. Right click on your files and click properties.
7. You will see attributes and click on the hidden box to unhide your files.
