How to fix Error 755?
Asked By 210 points N/A Posted on -
Hello friend,
Now i facing a error problem, that why i can not access my pc properly. I have some file with755 permission. Is this a security threat?
If possible to solve this problem, please suggestion me how i solve this problem. Then i can access my pc as previously and get connected between me & other friend. Thanks for your help.
Answered By 0 points N/A #127758
Repair this error immediately since this could damage your computer permanently if left unsolved. Just have your computer updated, will post the links on this reply.
Download these:
Windows Software Update
Error 755 – Error Code 0x2F3 Fix
Just download and install these programs on your computer in sequence. The spyware remover is there because 755 errors are sometimes caused by spyware and or viruses. Just run this remover together with a antivirus and you should be set. Let the tools work and then after, give the computer a reboot. Then try to reopen and use the computer, these downloads should fix the problem.
