john sa
200 points
Posted on - 07/01/2011
I am using one Windows 2007 server for the clients company. Last week, till today morning I put on the server and many users were accessing the server. Suddenly today when I tried to open the server remotely, it’s showing, "network path not found”.
I got shocked to see the error. Is there anyone to help me solve the issue?
tommy j
Showing network path not found error
Try connecting the server inside manually and open the command prompt ping. Check whether you are able to ping the server.
If you are not able to ping the server, then the server may be down. So go and check the server manually. If you are able to ping the server, then there is an issue with the network, so check the network cable.
Sometimes, if the services in the network like computer browser or the distributed file system is in off mode, then this kind of error occurs. So, check the service in the server, whether it’s in off or not.
If you're still getting an error, then restart the server once and try to log in manually and check it.
