Shows message that Memory could not be written in using two monitor
Hi
I have two L2230 monitors and I want to utilize it as a double screen with USB. I get that the USB drive from the CD clashes with several software of Window 7. Some examples are Internet Explorer also 3D max.
But I get the following error message.
Error:
iexplore.exe – Application Error
The instruction at 0xf6a87404 referenced memory at 0x006eedc0. The memory could not be written.
Click on OK to terminate the program
Answered By 15 points N/A #104380
You are installed windows 7 in your computer. There have few restrictions in Windows 7 for use applications or software. So you should turn into Windows XP operating system from Windows 7 operating system for use or support most of the application or software.
You may got this mistake rub for the pc file losing in your Windows 7. So I recommended you to re-install or repair your operating system. You may choose a new one too as Windows XP for fix this type of problem. After install your new operating system you won’t face internet explorer related problem again.
Thanks
Answered By 590495 points N/A #316593
If you receive that error after starting Microsoft Internet Explorer, try restarting Microsoft Internet Explorer. If this doesn’t work, restart your computer then try again. After booting, don’t open any other application aside from Microsoft Internet Explorer. If the problem continues, try using other browsers like Google Chrome, Opera, Mozilla Firefox, or SeaMonkey. See if you can open other browsers.
If other browsers run properly but not Microsoft Internet Explorer, try to reinstall the browser. Click “Start”, “Control Panel”, “Programs and Features” then select “Turn Windows features on or off” on the left pane. Wait until the window is populated. Next, uncheck “Internet Explorer” then click “OK”. When it is finished, close Control Panel then restart the computer.
After booting, repeat the same steps to access “Turn Windows features on or off” then check “Internet Explorer”. Click “OK” then restart the computer.
