Shrink 3.2 and Re-authoring Menus error has occurred
I am using Shrink 3.2 to Re-author and want to keep a functional menu which will prevent my backups from auto playing and starting immediately. I got this following error message when I was trying to drag the title of the movie. How can I resolve this issue? What should I do know? Is there anything wrong that I did? I need your help. Thanks.
Re-authoring Menus
DVD Shrink cannot retain menu functionality when you re-author a menu. Instead, all menu buttons will be removed, and the menu will be converted into a regular video clip.
If you wish to preserve the original menu functionality. You should backup this DVD in Full Disk mode.
Press OK to continue re-authoring the menu.
