Shutdown virus (registry files) command prompt as well
I can't access registry files without the computer shutting down, I can't even type registry files into google and search it without shutting down.
Hello there. Do not worry. You need to remove that virus from the registry file. For doing that, go to RUN window, type “regedit” and press enter. If you are prevented by the shut down virus then you will not be able to access the registry editor. In that case, download a third party registry editor for dealing with the windows registry changes. When you have opened the windows registry, select settings tab, click on “HKEY_CURRENT_USER” then look for shutdown autorun file by pressing ctrl+F and then delete the key value from that file. Then go to the program files and look for the shut down exe file virus and then delete it without opening it, delete it from the recycle bin as well. You may also check the task manager and search for shutdown exe virus file in the processes list or running applications list and right click on it and click End process. Hope your problem gets solved. Best of Luck!
Problem of accessing registry files without shutting down computer can be resolve by following instructions given below:
Firstly move to the START button on left bottom of your computer screen and click it.
See ALL PROGRAMS icon click on it and it opens a list of all your programs.
Find folder named ACCESSORIES and click on it.
See COMMAND PROMPT icon there and right click on it.
By right clicking menu opens see RUN AS ADMINISTRATOR icon in it and click on it.
Now enter your administrator password into the FIELD.
And then type” sfc/scannow” into command prompt without any quotation marks.
Finally press ENTER key.
After the scanning has been completed RESTART your computer to remove error.
Regards;
Adnan
