Shuttle: a fanless mini desktop
There are two models for the fanless mini desktop, Shuttle. It is the XS35V3 and the XS35GTA V3. What external accessories you need to pair this with?
Shuttle is mini fanless desktop which comes with a memory of about 4GB, They are not coming with any storage. You need to put your own storage. You need to install your own OS as it wont come with any OS. This means it supports all OS's. You can plug any devices which works with USB port the only thing that you need to do is to install the drivers in the system and make use of the device. You can insert mouse,keyboard, USB devices etc on it. You can even attach a printer to it which will support to your computer. The only disadvantage is you need to put your own storage device. Please see  the image below of the mini shuttle desktop.
Hi there,
Both of these desktops are enough equipped for any end user. Mostly I like the features of those are their graphics. Powerful enough to support high definition graphics works. Also it has 4GB RAM which also supports in graphics if necessary. It just needs to attach with a monitor and few input output devices. Also you can use RJ-45 with the adapter to get high speed internet connection. Also it can give you the opportunity to use wireless adapter through USB. Â
Thank you,
Riley weaver.
