I recently acquired 2 projectors from my friend’s office that purchased new projectors to replace the old ones so I told them I could dispose their old hardware.
Now, curious in the capacity of my new devices I want to setup the devices that the pictures projects are side by side each other to produce a panoramic display.
Will I be able to do that?
I want setup like this diagram.
earldio
Side by side projection image to produce panoramic image
We need to consider all possibilities, whether you use the projector together with a computer or as a tv with or without a tv tuner. We also need to determine if both, old and new projectors, can support a certain resolution. If you are trying to connect the projectors to a computer with dual video port graphics card, the answer is yes since most cards support extended display which allows you to split a single input and view it as panoramic. If have is a Macintosh computer, you can get the product name "Dual Head to Go" so you can split the screen and view it as an extended display. If you want to a TV using a Tv Tuner, you need to check the exact specification of the product first.
I Hope This Helps.
Hi Jenna Farmer!
You can set up the devices that the photos/images are side by side by each other that will produce a panoramic display. Have you ever heard about the DUAL or TWIN PROJECTOR invented by albrecht? This is probably the solution in your question. The Dual or Twin Projector projectors is adjustable laterally. It is arranged to take a picture/photos slide.The two projectors will project image/photos/pictures side by side by each other that will create or produce panaromic display or it will also can create stereoscopic display. You can do the research about the dual and twin projector so you can set up the device in your projector. I hope this solution will help you!
Thank you.
