Signature function not working in Outlook 2007
Hi Greg,
I guess I have solution for your problem as you know this problem you had mentioned here is actually problem caused due to less virtual memory. If you are able to free some memory for application this might work.
To do so, Please delete all temporary files and cache from your computer.
If this might not work then try this link .
Edward.
Hi Greg,
I will assume that you cannot access your signature after setting it up in Outlook 2007.
Double check what you have done because you might overlooked at something, as for me, I do it like this:
Make sure that you are in the mail section, click tools in the top menu, click options, click mail format and click signatures.
The window that pops up should let you create your signature.
Hope this helps.
