Significance Of The Error Code 2908 And Ways To Resolve It
I tried to install the Microsoft Office 2016 last night. I got an error code 2908 even before the completion of the process. I have tried it many times but the failure remains same. I am very frustrated now. Please help me to fix it.
Answered By 0 points N/A #290911
The problem can occur due to the corrupt installer. This error code indicates to installation process failure. You can try the below methods.
Method 1: Download a compatible version for your Windows System. Maybe you are trying an unsupported installer file. Get the Installer from Official Microsoft Website.
Method 2: Make sure that Windows Installer is working fine. There are high chances that the file is corrupt itself. You need to remove it and re-install it. Be sure that you install the latest version of it.
You can also try after installing.NET Framework on your machine.
