Significant and benefits uses of LG 24GM77 24-Inch
Hello, I need some answers about the following
How many VGA inputs are LG 24GM77 24-Inch? What are the USB port versions available in LG 24GM77 24-Inch? How many HDMI ports are available? What is Motion 240? How many speakers are available there? What is the native color depth and Gamut? Which graphic hardware is used in LG 24GM77 24-Inch?
Thank You
Answered By 0 points N/A #172669
Hello Garry!
Here are the best features of LG 24GM77 24-Inch.
1. Screen Size and Aspect Ratio – 24in / 16:9 /tilt angels up to 20 degree/ base detachable/swivel/pivot.
2. Max Refresh/Resolution Refresh – 1920×1080 at 144Hz support.
3. Native Color Depth/Gamut – 8-bit / sRGB or 72%.
4. Response time – 1ms
5. Brightness – 350cd/m2 one of the best and brightest LED monitor.
6. Speakers – None.
7. Video Inputs – 1 Display port, a DVI port, two HDMI ports and a VGA port, a usb port.
8. Headphone output and 110-240 V power.
9. Panel Thickness – 2.2in / 57mm.
10. Warranty – Three years.
Motion 240 is the ability of this LED not to flicker, no motion blur and or pixilation while on game. So you will enjoy the best throughput of your games and watching movies.
