Silverlight Error Code 4001 in Home Vista
Hi!
Currently, I am using Home Vista program. An error in Windows Internet Explorer occurred on my screen.
The error appeared has this code “Silverlight error message Error Code: 4001 Error Type: Download Error”.
How can I save a file in a specific folder without this error and without reinstalling the program again?
Please give the exact cause of this error and share resolution for this issue. Thank you!
ErrorCode: 4001
ErrorType: DownloadError
Message: AG_E_NETWORK_ERROR
OK
Answered By 0 points N/A #150302
Significant effects affecting Window Internet adventurer: Computer faults happen when your OS becomes occupied with debris and crucial files acquire removed or bribed. These types of troubles are the effect of not decently asserting your arrangement. Whenever left unchecked these troubles can effect in acute arrangement mistakes, freezes, and even a accomplished arrangement crash. Suggested: apply the costless Scan to diagnose Window Internet adventurer effects as well as additional troubles plaguing your arrangement. Once certified, this tool can amend the effects that mayhap causing your arrangement to misfunction while simultaneously advancing computer speed, optimizing memory, ameliorating security, and much more. Speedy PC Pro safely and soundly cleans the Windows registry to free it of faults that drastically affect computer execution. It focuses on such fields as ActiveX entries, divided DLLs (dynamic link library), uninstall entries, font entries, applications routes, file/track references, program shortcuts, file affiliations and much more.
