Silverlight licensed version on Radcontrols.
Hi.
I’m in an organization that uses Silverlight version 4.0.5 controlled by company’s policy.
We already tried using the trial version of Radcontrols for Silverlight and we find it useful. We didn’t encounter any problem not until we installed the licensed version.
We can no longer use some applications on our web browsers and keeps on downloading the latest version.
What Silverlight version do we need to run with the licensed Radcontrol.
Answered By 20 points N/A #105975
If you have license for Radcontrols for Silverlight then nothing to worry about it. Go directly to their website and inform them about this problem. It will be helpful. They will expand your license agreement or repair your current version or update it. Whatever they do it will be the best solution for this.
Other option is to do that manually. For this first install a windows registry cleaner then uninstall that application program and run any windows registry cleaner to delete all record form OS. Now reinstall it again and give the license key or put a different license key.
