Silverlight VoIP SoftPhone to Web Application
Can some body explain how to add a Silverlight VoIP soft phone to Web Application, I have been trying to do this for a while, using HTML, GUI. Is there any better way to do this.?
Html is a language fully known as "hyper text mark up language". Sometimes when your internet connection is slow it is desirable to load basic the html page for your email account.
After you finished all the steps mentioned above, register SDK.dll file to the Visual Studio Project. This step is necessary if you want to get VoIP in Visual Studio with the background support of Ozeki.
Then, open Visual Studio and click on: File/New/Project /menu to register your dll file to your project. In the Solution Explorer panel, right click on the References label and select Add reference from the pop-up list. If you do not see it then, check "C:Program FilesOzekiVoIP SIP SDKSDK" folder or select VolPSDK.dll from window. Now you are ready to build your own VoIP s application.
I hope this is helpful.
The second image and the third image will help you to understand how to register the DLL file.
