I am looking for a SIM Card reader with software that would work on a Windows 7 bit 64 system. All I could find were those that work on 32 bit systems. Please can an expert tell me where to look for such a card reader? Are there any available in the market?
SIM Card reader required for 64 bit system
Hi Adamswhitley,
There are various links through which you can download the card reader for 64-bit system. Some of the links are mentioned below:
A) PCL Reader 64-bit 11.1
1) Download the card reader from PCL Reader official website
2) It converts PCL and text into PDF, BMP, ASCII text
3) The size of the reader is 16.55 MB
B) USB SIM Card Reader
1) Download the reader from the USB SIM official website
2) It is used to recover lost messages and contact numbers
3) User can recover and print the messages from the device
4) The size of reader is 2.34 MB
C) Dekart SIM card reader
1) It is USB card reader and can be viewed on Amazon official website
2) The device is compatible with SIM card for many mobile operators
3) It searches, edit and deletes the contacts from the SIM card
4) User can exchange the contacts with Outlook through CSV files
