Sweetee
610 points
Posted on - 06/22/2011
I want to play Sim Theme Park on my laptop and when I try to install it, it gives me the following error.
Error
Unsupported windows version detected
Detected                                            Unknown
Required                                            2000, XP, Server 2003, Vista
This program required advanced features that are only supported by the above versions.
Now as per my knowledge, my laptop fulfills all the basic requirements for this game. Now the error generator also unsure about what It wants, as it says that unknown required.
I am quiet confused at this state whether, the error is from the theme park game installer or from windows.
Help me playing this game as it’s my favorite since my school time and offers you to play it too, you will really enjoy it a lot.
Unsupported Windows Version Error when installing Sim
Hello guys,
Generally there are 3 step to solve sim installation error on laptop.
When you face sims 3 installation error then its goes to your computer registry problems. You can use sims 3 installation error software for fix the problem.
You can try this easy step to solve your error.
Download Sims 3 installation error repair tool and install the error repair tool.
Open the sims 3 installation error repair tool windows and free scan your computer.
Click to repair all button.
Hopefully it will help you and sim installation error not appear to your laptop.
James ripon
chevin08
HI Sweetee,
This may help to your problem.Â
Before installing the game you should know the system requirements of the game, and you should know if your Laptop have meet requirements. Because if you don't have meet the system requirements of the game problems will occur, like in problems in installing the game, crashes when game starts, unable to start some errors are in the software and slow FPS like the game was moving in slow motion.
