Simple and easy to use SQL Remote Reporting Tool
I have a lot of data stored in my databases and i need to show my employees how to export from the database and show them how to generate reports from the same. They are not tech users so i need an easy simple SQL remote reporting tool that they will easily understand when i train them how to use & be able to work with.
Best Answer by Downer halt
Answered By 10 points N/A #163550
You can use apple remote desktop to show them the example of work. Most of the workers will be able to work with Microsoft Access and you can train them by using that software for training purposes.
Smith Thompson.
Answered By 0 points N/A #163551
Hello Mr. Johnny
Based on your problem, my solution for that is, conduct a seminar with your employees. A seminar which is related about the database with its usage and how could it be done.
Use Microsoft Access’s latest version to boost your employees because that software is easy to use and its also comprehensible.
Hope this one can help you.
