Simple introduction into databases elements included
20 points
Posted on - 04/10/2015
What is a database? What are records, table and field? What are the two types of database? What are the basic elements of a database? I’ve heard that there’s an old tool in VB 6.0 that can be used to create database? Can you show me how to create database using VisData? In this part, I just want to know brief explanation and simple instructions. Please do not overflow the explanation so it will be easier for me to understand everything.
Thank you very much!
