Simple JavaScript library for building
Hi expert, I tried to make a simple javascript library for building mobile web applications using jQuery 1.6.3. It is a fast, small, and feature-rich JavaScript library. But it is an old version of the jQuery. So, I cannot find several latest features. Please can you give me a proper URL to download a new version of jQuery for Windows 7.
Best Answer by Wade S Veith
Answered By 0 points N/A #157401
If you want to build mobile web applications with the latest featured Javascript library then you should try Jquery 1.9.1 version.It adds new features to:
1. HTML document traversal and manipulation
2. Event handling
3. Animation
4. Ajax
You can get it from http://jquery.com/download/.
Hope you'll find it very useful for building your mobile apps.
Answered By 65 points N/A #157402
A Java Script library is a library of prewritten script which allows for easier development of JavaScript-based applications especially for AJAX and other web-centric technologies.
JQuery  is a fast and quick JavaScript library that simplifies HTML document, traversing, event handling, animation and ajax interactions. It was released in January 2006 at bar Camp NYC by John Resig.
It is currently developed by a team of developers led by Dave Methin.
JQuery is the most popular JavaScript library in use today.
Here is the download page for jQuery.
