tia morris
20 points
Posted on - 11/05/2011
Is there a feature in Outlook 2007 in which the user can forward all requests and attachments to the Inbox of his meeting delegates. If so, please give me some assistance on how to set it up?
Simple Query on Outlook 2007
Hello Tia Morris,
For sure that there is feature in outlook that will allow you to forward requests and attachments. You just need to obtain the hotfix and then follow the procedure below:
You will need to quit Outlook in case it is opened.
Once done that you go to your computer desktop and then click Start, and then click Run, and in the dialog box you will type regedit, and then click OK.
From the window that will open you will need to locate and then click to select the following registry key:
HKEY_CURRENT_USERSoftwareMicrosoftOffice11.0OutlookOptionsCalendar
Once done that, you will be required to go to New which is on the Edit menu, and from there you will click the DWORD Value, and then you will need to type ForceMtgForwardResponse, and then press ENTER.
You will then just right-click ForceMtgForwardResponse, and thereafter you will choose the Modify option.
You will then need to type 1 in the Value data box and after that you will click OK and then exit the editor.
__
Regards
Clair Charles
