Simple Yet Reliable Ultimate Super Video Graphic Card
Hello!
I would like to purchase new video card. I would like to know something about GeForce TITAN X. What are the specifications? What are the best features of this graphic card? Does it include fan/s? How much is it in the market? What is the required slot for this card? What are the available ports? Does it support HDMI? Does it support optical connection? What is the speed in graphic throughput? Does it support multiple-screen connection?
Answered By 0 points N/A #174064
Hello Any!
GeForce TITAN X as all-in-one video graphics card with supreme graphics throw-put. The best features of this graphics card is that it provides fast and reliable graphics. This is the fastest GPU and memory buffer. Thermal efficient-induced device. It supports 4K gaming and virtual reality consoles.
Here are the specifications for the graphics card.
1. Clock speed – 1000 Mhz base clock speed.
2. Memory – 12 Gb with 384-bit.
3. Open GL version 4.5
4. Digital Resolution for VGA – 2048×1536
5. System power requirements – 600 W.
It supports G-Sync, GameStream and ShadowPlay.
Systems that are compatible with this card are Windows 8, Windows 8.1, Windows 7, Windows Vista, and Linux. It does includes fan. The price will cost you is $999. It does supports multi-screen display. It supports HDMI, Dual-Link DVI and 3 Display ports 1.2
