What are the simplest procedures to observe in order to service my LCD Flat Screen Monitor myself? I am a young student who loves to study electronic or computer hardware engineering in the near future. I bought a slightly used LCD Flat Screen and quiet currently, I have realized that the brightness of the monitor is reducing day in day out. I have checked from the brightness button and the developing fault has the nothing to do with it. I strongly believe it is a technical problem. How do I identify the exact spot of problem to be fixed? Thank you.
The simplest steps to follow in servicing LCD flat screen monitor
You may also try to adjust the different settings of color buttons. Adjust it to maximum and to the minimum settings. But before that, do the adjustment after about a minute or more when the unit was just turned-on for after so many hours of being turned-off, so that it would settled first to its normal temperature working condition. Observe also the power supply. Check if the plug is correctly connected with the AC outlet. Checking also the wire or the power supply cord for some chipped part but before touching the cord, make sure the TV is switched off and unplug the cord from AC outlet. Because, intermittent power causes fluctuations and may result to poor quality of viewing.
