The simplest wat to change application title bar
There are more than ten step to change the application mini bar, and its not effective. Tell me the simplest way to change application title bar .
Every app has a title bar by default. You can either change the name or remove the column entirely.
If you want to change the application mini bar manually it is a long process. If you want to remove the bar entirely it is easy.
To change the application mini bar you need to edit the values in the action bar. Follow the steps below:
1. Go to the application properties.
2. Navigate to the mini bar properties and click ok.
3. Go to the action bar and click edit.
4. In the new window, type actionbar=false and click ok.
This should solve your problem.
