Jeo Tolbert
Posted on - 09/19/2012
I am playing and ISO DVD image with my media portal through mount and play DVD, the players simultaneously play the movie. In effect, the movie is played twice. What I did was I used an external player called VLC player, the movie is played in both the VLC player and Windows Media Player. How can I fix this problem?
Simultaneous player opens when mount and play dvd
if your using windows 7 please follow these steps.
Start
on the search programs and files text box type in autoplay
 click on the "Start of stop using autoplay for all media and devices"
a window will be displayed showing the settings for autoplay
you will notice the DVD movie has play DVD using windows Media player
click the dropdown then select what you want the computer to do.
I hope this helps
Thank you,
