areldee
10 points
Posted on - 06/05/2012
I've read that malware and spyware that infecting our PCs can be removed by running an updated antivirus software.
Is there any specific antivirus software proven to effectively remove both infections?
Single antivirus software that is effective in removing both spyware and malware.
Perhaps no: the answer to this question is probably difficult, as it requires a single software to remove both spyware and malware
You will need “Malwarebytes' Anti-Malware”, this tool is available for removal of malware. And it also provides real time monitoring. This is one of the best tool which also removes “antivirus xp 2008” a spyware application.
Yet another solution is available named “VIPRE AntiVirus 2012” which provides dual protection for viruses and spyware. Viper acts both as antivirus and antispyware, it doesn’t slow down the pc.
Antivirus programs are designed to obliterate malware and spyware from a computer. I don’t think there is an antivirus application that only removes a certain type of infection or that only removes malware or only removes spyware. Both types of malicious programs are removed.
When a user downloads an infected file from a website, the antivirus program should be able to detect and block or delete the file before it reaches the hard drive. This is only possible if your antivirus program is regularly updated. If you don’t update your antivirus, it will be less effective no matter how good the program is.
Its virus signature database will become outdated and will only be able to detect the ones that the virus signature database can identify. Latest virus and spyware will be invisible to the program. There are different antivirus programs available on the net. Just select one and install it, keep it updated, and your computer is secured. Norton Security is one of the many antivirus programs you can try.
It is formerly known as Norton Internet Security. Another one is the ESET Smart Security.
Hi
Regarding on your issue also visit this Techyv link to get more helpful information to solve this issue.
How to remove a malware?
