Single instance Error message when opening Glovebox
        Hello everyone! I am getting an error when I click on glovebox application. At first the error appears at the top of the screen then it moves to the bottom after I click on Yes.
Error: Single instance Error
The application encountered problem while attempting to determine if any other instance of the software were running. The following problem was encountered.
Failed to open shared memory-failed to release mutex
Do you want to open the application anyway? If another instance open, the glove may fail to connect properly.
Exception thrown
Creating a view of shared memory failed.
At GloveBox.GloveBoxMain.writeHandle(InPtr hWindow)
At GloveBox.GloveBoxMain.OnHandleCreated(EventArgs e)
Application Exiting……..
The error message shown is also attached below. I cannot use the application most of the time because of this error. I have used it continuously but then I stopped using it for two months then now I decided to use it again. But when I tried to use it again, I cannot make it work this time. If you can give any suggestions that would be a great help and I would really appreciate it. Thank you.
