Ecas Muzia
Posted on - 08/09/2011
I have broadband USB dongle in my office. I want this single device for the multiple computer system.
I have no idea how it can connect and share all the computer of my office.
Can you guide me how this USB dongle device can run in all computer?
rony22
Single USB Dongle Device in couple of computer
At fast must be installed in the LAN device of all computer. Then create a wizard and finished the choice able system then LAN light will be building.
Next all dial up and VPN will be do setup and check your LAN server user name and IP address.
And all computer will be stay enable net work then you can run the internet all of your computer.
I am not sure if using a single broadband USB dongle is good for multiple computers to connect to the internet. I am also using a USB dongle and I’m sure if 2 computers will share on 1 USB dongle, they will have a very poor connection. Besides the fact that the stability of the USB dongle’s connection relies on the signal strength and even if you have a good signal the speed still varies from time to time. That is why it is not advisable to be used for more than 1 computer.
If you have multiple computers, create a local area network for these computers. Let 1 computer serve as the server to connect to the internet. The best internet connection for this is a broadband connection that uses cable and not with a USB dongle stick.
