According to 9to5Mac iPhone 4S will be more interesting because it has an additional functionality of Siri Applications. It will allows instant search, music control and more by a simple long-press of the home button.
According to the same source it will allows full screen mode. Can you give more convenient features of it?
Siri Application in iPhone 4S in more convenient way
“Siri is the intelligent personal assistant that helps you get things done just by asking”. Instead of typing you can actually command things, you just have to tap the Microsoft icon on the keyboard and it transforms your errands into words.
You can also dictate the iPhone to search the web, for example you crave for an Italian foods, you just have to verbalize the words and automatically it list down a lot of choices for you. Aside from that,it can search your contacts, control the music, read you email for you, organize schedules,post in reminders and notes,set alarms,inform the weather and stocks.
