SIRI giving trouble in my iPhone
I purchased an apple IPhone 4S. I can't communicate with SIRI properly. Why is this? Is this because of my ascent?
Hi Mitzi Lu,
Yes. Since Siri is on beta release but apple is continuously working on the availability of different accents. As of this time Siri has the standard accents of American English, British English, Australian English, German and French. And I’m referring into accents not the language itself. However, Siri is an intelligent application that is constantly learning. That means that more often you use it the more it will learn and recognize your accent. In general, Siri’s voice recognition works first by collecting enormous amount of data with your standard pronunciation of language. Other possible reasons are; weak cellular data connection or network provider’s data (internet) connection or no Wi-Fi connection, since either of these is required.
Let’s get to the specifications of your handset first. The Apple iPhone 4s is a 3G device operating on 2G and 3G network bands using GSM, CDMA, HSPA, and EVDO technologies. It was unveiled and released on October 2011. It measures 115.2 x 58.6 x 9.3 millimeters and weighs 140 grams. It uses a micro-SIM card with scratch-resistant glass back panel.
It has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 960 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass with oleophobic coating. It runs on iOS 5 upgradable to iOS 9.3.2 powered by Apple A5 chipset, Dual Core 1.0 GHz Cortex-A9 processor, and PowerVR SGX543MP2 GPU. Unfortunately, it doesn’t support microSD.
It runs on 512 MB RAM with internal storage available in the following capacities: 8 GB, 16 GB, 32 GB, and 64 GB. The primary camera supports 8 megapixels with f/2.4, 35mm, LED flash, and autofocus. The primary camera features 1/3.2" sensor size, 1.4 µm pixel size, face detection, panorama, HDR photo, geo-tagging, and touch focus. The primary camera can record video in 1080p at 30 fps.
It has a secondary VGA camera that can record video in 480p at 30 fps with video-calling over Wi-Fi and 3G. It has 3.5-millimeter jack featuring Active noise cancellation with dedicated microphone; Wi-Fi 802.11 b/g/n with hotspot; Bluetooth 4.0 with A2DP and LE; GPS with A-GPS and GLONASS; and USB 2.0. It has built-in accelerometer, proximity, compass, and gyro sensors.
The pre-installed Safari web browser supports HTML5. It doesn’t support Java. It runs on a non-removable 5.3 Wh Li-Po 1432 mAh battery with standby time up to 200 hours both on 2G and 3G. Talk time is up to 14 hours on 2G and 8 hours on 3G. It is available in black and white colors.
Siri is a computer program built into the Apple iOS mobile operating system and acts as an intelligent virtual personal assistant and knowledge navigator. To use Siri, on your iOS device, press and hold on the Home button until Siri asks “What can I help you with?” After this, say what you need. Be sure to speak clearly on your phone.
If you think Siri can’t understand you well, you can change its language. Go to Settings, General, Siri, and then Language. Siri supports the languages from the following countries:
Hi
To get more useful information regarding on your issue go this page and get more helpful information.
